Hey all I’ve created some workspaces in different units and no longer require them is there a way to delete them? Right now I have 4 workspaces all of different units with only one being worked on. I’m rather new to IOS so this could be something simple I’m simply missing, I did try swiping left but no option to delete appeared etc.
Workspaces view->Edit->Delete
Yes, there is.
To Delete Workspaces:
- Select the workspaces menu (four rectangles in the top left corner)
- Tap on “Select” (top right corner)
- Pick the workspaces you want to delete
- Tap on “Delete” (top right corner)
Ah perfect taping on the “select” provided the option to delete, I knew it had to be something simple yet still continued to elude me (5th day on ios ever). Thank you both for the quick reply.
