Use delete icon to delete folder from Item panel
Be able to delete folders in the Items panel the same was as bodies and sketches. This will create a more consistent UI. Currently if you want to delete only a folder, you need to hard press or swipe left to get the menu.
If you have a folder and a body selected, the delete icon is available.
Suggest that a better UI would be to have the delete icon available if a just a folder is selected.
I think this behavior has improved. Can you add the ability to delete empty folders with the delete icon? In this context, “empty” is to mean empty of bodies, sketches, geometries and images. Nested folders (folders within folders) with no content would be considered empty.
