I tried to change the dimension of the image imported from 23mm to 80mm but it says out of bounds. Anyone help, please!
Could you enlarge it at all?
I am having this same problem. I have tried multiple ways of importing an image and every time I try to change one of the dimensions I get the same error message as yours.
Hello, please send the .shapr design file and a screen recording of what you will like to achieve when you get the error message to support@shapr3d.com. We will then further investigate the issue and get back to you as soon as possible. Thanks.
