Grouping object together
Hi all
I’m still struggling with this
Is there any tutorial that covers how you group and then assemble different components
I’m finding that as I build an object with multiple facets every time I try to move it in a space I have to select each section of it which is a pain
The best way to describe the challenge us to say if I’m building a bike
I would like all components of the wheel to be in one file movable as a complete unit
But if I try to move it I have to select every spoke rim and tire
Surely there is a better way
Can someone help
Thanks in advance
Place the associated components into a folder. When you want to move it around, just select the folder, which will select every item in the folder, and then do the move.
Ok thanks will try that
