Is there any way to group objects?
As the title says. It would be great to group objects, and then to move them together as a single entity, instead of moving each object individually.
You can select multiple items, then put them into a folder within the items column. Then select the folder, and move the entire group of items.
Beautiful. So elegant. Thank you.
