History Based Search?
Thoughts on adding the ability to search the History for Dimensions that are input?
Example would be if you know a dimension that needs to be changed for a certain extrude, or feature and do not know exactly which feature it is under. Being able to enter the Dimension value and have it highlight History features that have that value for you to quickly look through.
This could also be a step toward even deeper Parametric Modeling much later down the road by eventually getting into Variables that can be searches/called from a spreadsheet?
Good idea!
