How do I get the center of the circle on the model to be marked in a new plane
How do I get the center of the circle on the model to be marked in a new plane. Before it worked by pulling a line to the circumference of the circle, seems like it doesn’t work anymore after the update. Is there a new way to do this?
And the name of the newly created plane is also different from the previous one
You can achieve same result as before by using projection.
Thank you very much, I have not used projection before. :partying_face:
