How to “drill” a hole?
I have designed this pipe (several cm long) and placed it through a 5mm wall.
How can i open the hole in the wall with the diameter of the inner diameter of the pipe?
Use the offset tool/paralell face at pont you can draw a cirlcle on it, extrude to the right direction and subtract from your tube
R
A
