Images in folders forget transparency settings
Problem description:
When you change the visibility of the enclosing folder, images inside the folder are loosing their transparency
It seems to be more like bug than feature request, but may need a look.
Steps to replay:
  1. put images into folder
  2. change images visibility to 20%
  3. Switch enclosing Visibility OFF
  4. Switch Folder visibility ON
  5. Images previously set to 20% are fully visible.
To make them back to 20%, you have to manually, change 20 to 21 and to 20% back again.
One by one :frowning:
Thanks for reporting it, we will look into it.
Hi! We found a fix for the issue, likely to be deployed in version 5.450. Make sure you keep Shapr3D up to date!
Thanks. It works fine now :smiley:
