Kettle tutorial. Can't change dimensions correctly
I’m following a Kettle tutorial, and at the point where the handle is created from a rectangle, after adding circles and removing unnecessary lines, the object gets distorted disproportionately. However, everything works fine in the tutorial. I can’t figure out what’s wrong. Link for my video, last seconds: CleanShot 2025-01-20 at 01.49.27.mp4 - Google Drive
Link to tutorial moment: https://youtu.be/IO3CaqhOXp8?si=mKsHTE6fK8rOjAHL&t=890
Thank you!
UPD: Sorry, I have read about the constraint tangent, all works fine!
Check show all constraints and investigate from there.
I think if you set dimension of the bottom circle, it will not distort. Essentially your circle got bigger with length distance changed.
