Lock Grid Size After Each Launch
Each time I launch Shapr3D on my iPad Pro I must reset my zoom level and relock my grid size. Is this by design? Is there a preference that I can set so that my grid size is always locked, or, at least it stays set on a design once I lock it? Thank you very much.
Respectfully,
Trey
That’s the way it works for me too. I just took it for granted and don’t have an issue with it.
Hi!
You mean the Lock Grid Size setting, right? The app used to remember the state of this toggle but due to a bug now it doesn’t. The good news is that we’ve found the root cause and you can expect a fix in the upcoming releases!
Hi!
The bug should be fixed in 5.430. Since you mentioned the iPad, I assume you installed Shapr3D from App Store. This means that you app should update to 5.430 in the upcoming week automatically (unless you have updates disabled).
