As a sketch I’ve created 3 simple rectangles. I want to move them and I can’t.
I get the notification " locked points can’t be moved " when in sketch mode or “Transform failed because sketch constraints couldn’t be solved” when I exit sketch mode.
This is after I unlocked these under constraints. I did not lock them in the first place?? Auto constraining is off?
100% a bug and still happening. I’ve tried to unlock the center point of a sketch numerous times. I rebooted as well to be sure its isn’t another Shapr memory leak issue where functionality just drops off until it’s restarted.
