Quitting
Unintentional quitting user error.
Consider a confirm button when quitting as the command/ Q is quite close to Command /1
This will stop you accidentally quitting when meaning to get into standard view:
a number of times I have mistyped the Command /Q button meaning to hit Command /1, unfortunately unlike other commands there is no undo so I loose my history
A simple confirm box saying ‘do you really want to quit’ with a check box or just need to hold down Command/ Q for two seconds to quit.
Hey sebb,
Thanks for posting this! This feature is not in our plans for the near future. Check out or History Based Parametric Modeling beta where the history tree doubles as a full-length permanent undo/redo queue, making this less of a problem.
And in the Mac / iPad versions, don’t let ⌘ W close the application.
