Hello,
I made a volume with vertical stripes. I want to achieve the same volume with 45 degree stripes. The volume changes when I rotate the top face 90 degrees. Maybe there is a solution to this problem.
Thanks in advance.
Hi, if you have created the body by lofting at least three cross-sections, please rotate the cross-sections before lofting. In your example the top section by 90°, the middle section by 45°. The gradual rotation will result in a smooth transition and will not affect the shape that much.
I am not if the 45° and 90° will give you the result you are looking for, but I hope to rotate the sketches helps
Thanks for your quick return.
Thanks for your reply and the link. I will try this solution.
