Below I have detailed a scenario which I believe is a bug
- Sketch a circle (or any other)
- Set circle dimensions by clicking dimension label
- Choos scale transform tool
- Scale the sketch using gizmo or by value
- Error! “Transform failed because sketch constraints couldn’t be solved”
But, on the other hand the below works
- Works!
To conclude, the error "“Transform failed because sketch constraints couldn’t be solved” appears only if the sketch dimension was set by using the dimension label
