Segmenting Shading
Please see attached screen shots.
Looks like the shading of a circular sketch will “segment” when you zoom in and the line remains a true curve.
Wondering if someone could confirm this for me?
Cheers
In addition, the body I have extruded is also segmenting. Is this just how shapr renders cicles?
Hi Dylan,
Yes and yes. When you zoom in very close the visual representation can look “segmented.” Here is a 1000mm circle and zoomed in to edge, also extruded circle. The last screenshot zooms in at the circle edge where a radius is measured. The coincident constraint appears not exactly on the circle.
This is nothing to worry about.
Thanks Bob! I was having SketchUp ptsd and was worried. Just checked the DXF and it looks smooth.
Cheers
