Hello I’ve been using Shapr3D for about 8 months got pretty used to all the tools in the tool box but I can’t figure out how to create seamlessly à ship hull mesh. Adding spline points to a volume or if there’s an alternative way to do it.
I’m kinda stuck with a box shaped ship any hint would be appreciated
Hi Maroun, you should be able to attach images and short videos now.
Please can you attach images indicating what you will like to achieve to help us better understand.
Loft it using cross section drawings on construction planes spaced apart from each other.
Hello, I would like to draw the hull using curved lines rather than sections. Do you have any ideas on how to approach the problem?
The use of guided Loft may work for you.
Guided Loft as Mike suggested. It’s the easiest way to do it.
