Stand from Profile Sections
Ref:
Jayemery 37m
I there a tutorial somewhere that shows the best way to build tubular weld assemblies. In s3d
I’m trying to draw the 3d version of my oven supports made out of a stainless steel 25mm x1mm thick box section
Is it best to draw the whole thing as lines and then sweep them
Or actually draw a box section and extrude each section
A common practice approach would be helpful
Even if we start with just a frame for a cube
I can hopefully work from there
Jay Emery
I have started a new topic rather than impinge on the OPs Thread.
Clearly you will have to set out your dimensions and use the desired Profile, solid has been used to enable the Clip to meet the maximum size for Videos:
