STL exports : wrong size and packed in ZIP
Since last update (October 30 2025), It seems that the STL export is now packed in a ZIP File.
This should be an option, cuz it is not always what we need.
The second issue is about he dimensions.The STL file seems to have weired dimensions. Maybe an issue with the units.
It packs to .zip only if you choose option “Save Each 1st-Level Item Separately”.
Thank you very much. I did not know.
