Shapr 3D provides 2 options for export : regular and quick
The regular option allows to export a ZIP with all first level (not hidden) items. On my iPad this function is unreliable : it randomly group visible items in one stl instead of creating as many stl as first level items.
I could’nt find any constant in this misbehaviour and it is very annoying in terms of productivity.
Or may be I’m misunderstanding what a first level element is : does a directory with elements inside be considered as a first level element and inside items a second level?
Does the content of a directory exports a a single stl?
I’ve never used this function before, but a quick test shows the following: if you collapse all folders, you’ll see only the top-level elements — each visible body or folder at that level will be exported as a separate file.
I tested this on both Mac and iPad, and they behave the same way.
OK solved I guess I did not understand the "first level " concept thought that when I only had directories the item inside where first level.
Thanks for you support
