Surface mesh adjustment
Hey there, couldn’t find this topic so apologies if it’s been brought up before.
It would be great to be able to push/pull surfaces created. For example you you loft a car door panel and then you can select the new surface which then shows the mesh with control points. You can then select the vertices to pull out a bulge in newly created door panel. Possible?
Thanks for an awesome CAD app guys!
-Alan
