The stakeout cannot be merged after it has been successful
I successfully staked out two faces and two curves, forming solids that I couldn’t merge with other solids. This is an irregular entity, but the regular entity can be merged normally, I think this is a problem, he bothers me a lot, I hope to be able to help
help help help
Shapr3D - X - 9 September 2024 (loom.com)
Tu oublies le contour bas situé le long de la pièce 1. Il y adonc 3 contours à sélectionner.
It worked, and that’s really the reason for the lack of sidelines inside, thank you.
