Unable to export
Hi there,
When I export I don’t get any prompt for where to save the export. It just says ‘Export Successful’. Where are my exports going, if anywhere?
Cheers
Andrew
Hi - would you be able to send me a video of the problem (iOS 11 has a built in screen recorder) . That would be a great help.
After you tap on export a Modal from apple should show up. Like this:
Hi Daniel.
I can’t send you the video. It says the file is not authorised.
To describe the issue, it’s taking me straight to ‘Export successful’ message without prompting me for a name or location.
Previously this had worked as described in your video. It’s only recently I can’t export.
UPDATE: Ok so I’m a muppet. Rebooting the iPad resolved this.
Cheers
Andrew
iOS 11 is a muppet, not you :slight_smile:
