Unable to select segments of a sketch for deletion
I created a sketch having many parts. I was able to delete parts of the sketch I did not need. However there are two arcs part of which I’d like to delete but when I try to select a part of the arc, the entire arc gets selected.
I’ve tried unlocking/disconnecting the parts of the sketch but I’m still not able to select part of the arc.
Please let me know how I can delete a segment of the arc.
Thanks,
Regards,
Ajit
Don’t try to select segments of sketch, you can’t. What you need is the Trim tool in sketch mode. What does the Trim tool do? – Shapr3D Help Desk
Thanks Zoli. I did try using the Trim tool but it was still selecting the entire arc.
I’ve managed to resolve the issue. I deleted the arc and then found that there were multiple arcs, segments of arcs and lines as overlays. So it was not just one arc or line. I deleted all the arcs and lines and drew new ones. Then I was able to Trim sections as was required.
Thanks again.
