Variables in the pattern tool and variables carry over to the pattern also would be nice to have variables in the polygon tool
Pattern tool should let you input variables.
Also if the original sketch has variables that should carry over to the pattern.
I use polygon tool as a guide to create patterns would love to add variables to the amount of sides I want to create.
Save time by using variables, but variables are missing in these key areas.
Time can be saved if I apply variables to the spacing, count of patterns and the variables carry over when you disconnect the pattern.
Expression support for pattern will be released in the next few weeks.
Downloaded a new update today! Still waiting!
