ZSU-57-2 Soviet self-propelled anti-aircraft gun
The ZSU-57-2 Ob’yekt 500 is a Soviet self-propelled anti-aircraft gun (SPAAG), armed with two 57 mm autocannons. ‘ZSU’ stands for Zenitnaya Samokhodnaya Ustanovka (Russian: Зенитная Самоходная Установка), meaning “anti-aircraft self-propelled mount”, ‘57’ stands for the bore of the armament in millimetres and ‘2’ stands for the number of gun barrels. It was the first Soviet mass-produced tracked SPAAG. In the USSR it had the unofficial nickname “Sparka”, meaning “twin mount”, referring to the twin autocannon with which the vehicle is armed.
That’s amazing :star_struck:
Thank you, Rohan👍
These are amazing. You should 3D print and paint them. :slight_smile:
Thank you so much. But I think my 3D printer will not be able to do all the small details. But I promise I will try :slight_smile:
I guess it depends on the scale… You could print a veeery large one :slight_smile:
I’ll try;)
Have you looked at the Voron 2.4 self build ? I’m sure that would build it without too much trouble :smiling_imp:
I have Flashforge Creator Pro :wink:
@Antey85 have you modelled the KV-3 yet I fancy modelling a tank.
What rendering software do you use?
