Lines in .png exports
As mentioned before, I’m using Shapr3D to create CNC carvings. I currently can not afford the .stl import software for my machine. So, I create in Shapr then export a .png that I want to import to my software. However, when I export there are lines in the objects that the carving software will cut into the wood. Is there a way to export clean .png files without these lines?
See the below pictures for the evidence of the problem.
Thank you!
EFFB46CF-E7A5-4189-8B49-4FE2A374EA9A15E83817-6AB4-4172-85C2-9EF9CB42F66F
With the current version of the app (2.2.6), you can’t hide those lines during png export.
