Problem: parametric application update
Hello,
I just found out that I was eliminated from the Parametric Beta updates. Is there a reason?
Why don’t I have an answer to my questions?
Hello Alainblanck,
Sorry, but was wondering did you load Test Flight?
Hello,
How do I recover my access to beta version updates?
Sincerely,
Alain
Hello,
I would try going to the Apple App Store and do a search for the App Test Flight. From there the App will direct you to the Shapr3d App.
Hello,
I deleted the Beta application, then reloaded it, but the problem is still the same.
Warmly
Hello,
Via Test Flight? It should work.
Best
Hello, please open a support ticket here: https://support.shapr3d.com/hc/en-us/requests/new, thanks!
Bonjour,
Votre site ‘Support Ticket’ est tout en anglais, sans possibilitĂ© de faire une traduction.
L’impossibilitĂ© pour moi d’avoir accĂšs aux mise Ă  jour de Shapr3D paramĂ©tric n’est pas modifiable directement depuis chez vous ?
Cordialement,
Alain
TestFlight is garbage. here is the workaround!
  • Make sure the test flight app is up to date
  • In TestFlight, select Shapr3d beta
  • Scroll down and hit Stop Testing
  • Redownload the beta from here Shapr3D Parametric Beta
Hello jamesloper, I applied the method you suggested, and I recovered my Parametric Beta version in its entirety. I thank you for your sympathy, and I wish you the best for the future. all my thanks, Alain.
