I need help creating an eye bolt. This is for a 1/10 scale rc vehicle.
Can you be a bit more specific with this. Visuals also help
Does this help? In the picture there are small eye bolts. I’m trying to create my own and print them
There are several tutorials dealing with threaded bolts. In your case you can form the ring/eye part above the threaded part using the Sweep tool.
These look a bit tiny to 3D print to me. What’s bad about standard metal ones?
I’m trying to learn the tool and wanted to try an eye bolt. Thanks
Thanks Tommy.
yes, for the threaded part I’d check out this tutorial: https://www.youtube.com/watch?v=khAnIZ09uYQ
and for Sweep: https://www.youtube.com/watch?v=uWyVUO5i6aY
