2D drawing reset after adding bodies
One thing I find very time consuming with the 2D drawings is the need to start from scratch each time I add or subtract a body in the views.
As an architect my designs are always evolving through a project with the need for constant revision of drawings and so it isn’t unusual to be adding/subtracting bodies for the views and drawings. And to make it worse, the majority of architectural drawings are base on sections through the model.
So, if I have several sections through one particular view adding/subtracting any bodies requires a new view and then redoing all the sections. This results in all dims on the drawings being lost and any note arrows. I have to create a new view, cut all the sections again, place them on the drawing and redo all the dims and notes. All very time consuming.
Essentially the design has to be totally complete before producing the 2D drawings which isn’t practical or how it works in reality.
It would make a huge difference if adding/subtracting bodies from 2D views didn’t require starting all over. If I change the size or position of a body then all is ok and the drawing will update. The problem comes with adding/subtracting bodies.
So far the 2D drawings are a good start but there’s a long way to go - especially for any disciplines like architecture that require regular updates to the design (also looking forward to the ‘detail’ views for which the temporary placeholder button seems to have vanished).
Thanks for all the hard work.
Simon
Agreed, this is a problem. Why can’t we subtract bodies without having to start the drawing all over. Very frustrating. In addition to not being able to remove bodies, there is a similar problem with moving bodies in the original model. Moved bodies will appear correctly in place in the model, but out of place in the drawing, once again, requiring one to delete the drawing and start over from scratch.
I didn’t see a response to this issue but thought I’d give my input if it hasn’t been resolved.
One work around to this is to union the desired body to an existing body in the view. Go to the drawing and update. Then go back to the model and use split to recover the original bodies. It will want to delete the drawing but select keep drawing. Go back to drawing and update. Done.
It’s not an elegant solution but will save you time, especially if you’ve done a lot of dimensioning.
I really wish that the Shapr3d team would address this problem when adding new parts to a existing design so that you would not have to do the work around that you described or redo the drawing over completely. It really surprises me that this is not being pushed to the front to get a solution for this. this is a real deal breaker when making drawings of our designs.
Thank you
I agree.
You would think that having the ability to add new bodies when creating a new view would be the foundation to edit views to add or subtract other bodies.
Hi, I don’t do many drawing but several times recently I’ve had drawing just disappear. Is this what you mean when you say you have to recreate a drawing?
I have a similar issue where I’m making drawings of I-beams with connection plates — every beam is different. After duplicating a base beam, I need to add additional plates to it. To update the drawing with the new bodies, I perform a Boolean union between the old body and the new one, then update the drawing so it recognises the changes. After that, I delete the Boolean operation from the timeline history — the drawing stays updated with the new geometry, but the bodies are no longer joined together.
