I was trying to edit my drawings sheet and add different drawing angles but now the option is not available. I used to be able to add more drawings to my current sheet without having to make a new one. Here are a couple of screen shots of what I’m looking at.
Would you like to add a new reference bodies to the same drawing? If so, it is still possible, but it’s been moved to a different location. Check out this tip: 5.460 - Base and Projection views in 2D Drawings - #24 by Alexander_P
If it’s not about new bodies, could you please clarify what you mean by different drawing angle?
Thanks, I had the same issue and your reply helped me very well
