Hello,
I’m planning to make a DXF-file that is meant to be used for a waterjet machine to cut a PE-sheet into parts. With these parts I’m planning to make a water tank for a hydroponic systems to grow some herbs. In the below picture you can see the PE-sheet that’s 2000 x 1000 mm. I’d like to cut this into 3 rectangular sheets, one 254 mm x 1000 mm, and two narrower ones 70 mm x 1000 mm.
From the third piece that also is 70 mm x 1000 mm I’d like to cut trapezoid-shaped parts that shall serve as end caps of the water tank. I will post these in a new post as I can only upload one picture a t a time.
Since I’m a complete novice in Shapr3D I would need some support to make the DXF-file.
Thanks very much in advance! Zumen
