Ability to add images as textures
It would be useful to simply add images as a texture to the models. This allows quick mock visuals. Take an instance of creating an exhibition layout or an interior space where you need to show graphics on a wall. This can’t be achieved without using a third party render app.
You are then in the issue where there could be updates to the models means reimporting and redoing textures etc. The same is true if you want to take a photo of a difficult texture to use in conceptual design. Simply being able to add an image as a texture and exporting a visual directly from shapr would rapidly increase the workflow.
Take a look here.
No native texture/image support for applying images directly onto surfaces.
No basic rendering capabilities, so mockups require export to third-party tools (Blender, KeyShot, Twinmotion, etc.).
Reimporting hassle: Any updates to the model mean repeating the export > texture > render process, which is tedious and error-prone.
