Aligning 3D scans in Shapr3D
I have an imported mesh (STL) I would like to align to XYZ of the model. I have added planes from 3 points, then midplanes and an axis—my expectation is to be able to use that for alignment, but I cannot. I can only ‘eyeball’ alignment, but given this is a 3D scan, I would prefer automatic alignment for accuracy and speed. If anyone has a method I can use, it would be appreciated.
I hit the same wall with scans. As far as I can tell Shapr3D won’t use construction planes or axes as a target for moving a mesh body, so what has worked for me is fixing the orientation before the import:
  • Meshmixer (free): Edit > Align. Select a flat area of the scan as the source, pick the target axis (for example Y up), accept. Do it again with a second face if you also need the rotation around that axis locked. Then Edit > Transform to put the origin where you want it.
  • MeshLab (free): Filters > Normals, Curvatures and Orientation > Transform: Align to Principal Axis gives a decent automatic first pass on longer parts, then Transform: Translate, Center to move it onto the origin.
Export the STL again and import it into Shapr3D. It comes in on the world axes, so your sketches line up without eyeballing.
If the part has a flat datum face, use that face as the first alignment target. A fit over a whole face is usually more accurate than three points picked by hand on a noisy scan.
