Hello,
If bends are not yet implemented in Shapr3D, could at least bend lines be allowed for inclusion in exported DXF files?
Currently, I need to go to outboard apps to add them.
I know this is a small concession until bends are fully implemented.
Thanks.
Hi mcbrems,
Can you explain with screenshots
I suspect he means the lines at which sheet metal or wood needs to be bended during the construction process.
Since Shapr does not do sheet metal bends, it would be awesome at least if it could allow the inclusion of bend lines in the sketch for DXF export, so that third party fabricators can apply bends to our projects. The attached screenshot shows a red/dashed line that I added using LibreCAD after the DXF was exported from Shapr3D.
