being able to copy the outline (even if by selecting all the vertices) of a very convoluted/non-geometric (yet flat) surface feature to create a sketch model that duplicates that surface as the base for another drawing
duplicating a surface to create a matching component in another object drawing .
Spend hours trying to perfectly duplicate a complex flange outline with arcs, and lines and have all the holes and etc match perfectly
example pic
yes…BIG slow down having to manually try and duplicate a mating component outline
