Hi I’m new to Shapr3D. I have a model that I need to cut a angled hole through. What’s the best way to achieve this? Unless I’m missing something, I can’t seem to find an option that after creating the sketch of a circle to be able to extrude it through the object on an angle. Thanks
@JoeT71
Welcome to the Forum.
This is just one MO.
Form your Circle into a Cylinder
Tap on the cylinder and use the ‘handles’ to orient. It into position
Then use Tools > Subtract.
Hi Joe, to help us better assist you please can you upload a screenshot of your model marking the point where you like to have the hole.
You could create a construction plane, create a sketch of a circle on it, rotate the plane to the angle you need, and negative-extrude the circle into the part.
There are many ways to make an angled hole. Here are a couple.
