Bending sheet metal
Notwithstanding that the metal sheet thickness may not remain the same when bent, here is a simple-minded approach.
Basically do a cross section outline of the bend and Extrude. Then Transform/Rotate a copy 90 degrees and then Translate one top corner point to the other. Extrude to complete.
I exaggerated the bend for clarity.
image image image image
Notice that the cutout is a 1/4 ogive (bullet shape). So a simpler way would be to Shell out your box and Subtract the 1/4 ogive from each corner. Create the ogive with a cross section and the Revolve tool. Once you determine the dimension for each thickness of sheet metal this would be very easy to do for a given corner cutout. You will have to trade off the radius of the bend with the fold up gap.
If your bend is not circular (the metal stretches at top and compresses at bottom), it gets more complicated and if you try to bend too sharply, the metal will usually crack.
I once worked in a sheet metal stamping plant a long time ago. Can still hear the kerplunk of the presses.
Hope this helps.
