Bug: Hiding a body doesn't prevent it from affecting selection of coplanar sketches
At least, I’m assuming this is a bug.
Steps to reproduce:
  1. Draw on a sketch plane (Sketch Plane 01)
  2. Extrude from the sketch plane
  3. Hide the extruded body and related sketch plane
  4. Create a new sketch plane coplanar with Sketch Plane 01 (thanks for allowing separate coplanar sketch planes, btw)
  5. The new sketch plane is impacted by the hidden body (but it appears to remain separate from the hidden sketch plane).
CoplanarBug.shapr (11.2 KB)
Hey @Justin,
We will improve this behaviour as we keep polishing the experience. In the meantime if you open the sketch step in the history you can disable automatic imprinting.
Let us know if that helps,
Matyi
Thanks, I was unaware what this option did.
