Calculate inner volume
Good morning (o;
Does someone have an idea how I could calculate the inner volume when I use the case tool
with the help of an external tool?
Basically what I want is the amount in liters to compare different speaker designs.
thanks in advance
richard
For example:
At first make a copy.
Make a bigger body , perhaps a cube, subtract your body from the cube,(use folders) delete the outer part, and you will get your inside body…
Just perfect…thanks :slight_smile:
Didn’t much pay attention to the bottom status bar before showing the volume and surface (o;
Too bad it won’t show the volume when all inside surfaces are selected therefore building a closed body…at least the surface area is the same (well almost ;o):
