Can I copy/move these faces to another object?
This is a Gridfinity and I need to put those ledges in each bucket. Is there an elegant way to copy the blue faces to another bucket?
Copy and move the body a bit, then use the Align tool to move/align it to the other body.
Thanks Laci, I can only move the part if copy is off strangely. There is of course a STEP involved so I guess bad things have to happen.
Somehow doesn’t make sense it can be moved but not copy-moved.
Can you upload a short video of the problem?
Sure here you go.
Are the blue faces in your pic a separate body? Or, are they faces that are part of the larger surrounding body?
If a separate body then you can do what @Laci_K suggested. If they are in fact part of the larger body then you cannot copy/paste to another body.
Yea, as @TigerMike said, it looks like you are not selecting the whole body, but 2 faces. You can copy-move the whole body if you select it.
Ah OK I see the logic now thank you guys. So instead of drawing on the back of the cup I should have added a plane and draw on that? Is that making sure it’s a separate body?
It’s not necessary. By default it will be a Union with the original body, but you can change this setting in the boolean menu:
You van also cut the already created body with the Split body tool.
