So the thing is: I have a ball (which should be a nose) and projected two sketches on it (which shall be nostrils). I now want to extrude these projections to get a projection equally deep on the curved surface. I already did this a few times and it worked great, but this time the error “Operation failed because the resulting body wouldn’t be valid”. The preview of the action looks great though… Any thoughts?
Potential workaround: Place a construction plane in front of it and project the oval to the plane. Extrude it and then use “Replace face” to meld it back to the main body.
Great idea, but I cannot select new body upon using the face replacement. Therefore the hole is just filled again and I cannot adjusted the heigth of it
