Projection extrude fail
5.490.0.5960
after fiddling w projections, trying to extrude a projection resizes the whole body
works on other projections on same body tho
projection extrude fail.shapr (22.0 KB)
sanity, check, confirming it usually works with that shape
also i would have expected the rectangular projection to resize with the main body unless constrained somehow (which it wasn’t afaik). in the video ^^
Having the same issue. Trying to create a knurled surface for a knob. It just re-sizes the body.
If I shorten the projection I can get it to work but if it wraps around it resizes the body.
