Cannot set distance/space between two "objects" on Mac
Hi All,
First of all forgive me if I am not using the correct terminology, but I am rather new at this so bare with me.
On my iPad I have the ability to select two points and set the space between the two objects. In the picture the green circles show the points I selected and the red circle shows the distance/space between the two points.
Tried this on the Mac and it doesn’t work. Followed the exact same steps, but when I select the top end-point it doesn’t show the the distance.
Any help would be appreciated.
Rohan
Hi!
Did you press Shift while selecting the second point? Selection is greedy on the iPad, but on the Mac it’s using the more common way.
Virtual hugs allround! Thank you so much, did not think about pressing the shift key. Totally solved the problem.
