Hi there, im following the tutorial but i can’t move spine line down.
The error above says you can’t move locked parts, so just unlock them before moving. For tutorial purposes, you can simply select everything using the constraint filter and delete all constraints.
These videos shouldn’t be seen as interface tutorials, but rather as examples of modeling approaches. For working with the interface, there’s a manual on the website, and the official channel also updates its videos from time to time.
I often watch videos made for completely different CAD programs and apply the techniques in Shapr3D. The general approaches are more or less the same everywhere, while the interfaces differ — so don’t let the interface distract you from the core techniques.
The Union button exists for sure ![]()
Shapr3D has interactive interface, so to see some control elements you need to select objects they will work with.
https://support.shapr3d.com/hc/en-us/article_attachments/11017077131036
