So, I came across an interesting issue. After starting Shapr3D for the first time and working through the tutorial section I could not move forward because the video box was in the way which blocked the parts i needed to click on to move on… Any ideas on how to get past this?
If you are using Scaling in Windows, taking it down to 100% should solve the issue. You can turn it back on once you are pass the tutorial, everything should be fine in the modelling space, we are planning to fix this issue.
