Well, since the newest update, while making a custom threaded 3dp screw like I normally do, (The new thread tool isn’t as customizable as I need, which is totally fine), when I subtracted my threaded screw it left multiple holes through the model that have no face (its not just invisible, there is nothing to select and trying to select a theoretically “invisible face” selects whatever is on the other side of the object as seen below.) There is also dozens of random lines or faces that should not be there and are not present on the piece that was subtracted.
(tried selecting where the missing face should be and selected the other wall)
(Weird line and face that should not be present)
I assume it’s related to the odd geometry, but it may not be, with the same update I can no longer export this model either. I can export other models in the same project, but when I try to export this one? I get an error every time. If this is a bug that’s okay, hopefully its not a corruption. Luckily I have backups without this feature.
To clarify this does not happen with simple subtractions like from a cylinder or a cube or even more complex sketched shapes.
The way I created this hole is as so: 35mmx10mm cylinder, put axis through outer cylinder, put plane on axis, sketched thread dimensions, revolved thread, subtracted thread and threadless-screw from main body, move screw 2.075 over (because 2.1 left some weird clipping i could see on section view), subtract again, move back. Then I add tolerance by moving every face of the thread cut .2 outward (-.2 on the walls, -.2 on the inner and outer rings) Now I have a smooth thread going thru the entire thing and everything should be lovely. This has worked for me with 11 completely different original designed screw with all sorts of screw sizes and thread dimensions. It’s tedious but how I to do it for custom screws.
Any ideas why? It’s either the update broke something or the weird 2.075 movement I did that jacked everything up. I can just delete the threads and make new ones if It’s my fault.
