I want to challenge everyone to draw a right triangular pyramid.
I found that building a right triangular pyramid with a few simple steps is not so simple.
Tomorrow I will show the solution. Good luck!
You noticed a problem haven’t you ?
If the peak all 90 deg…its easy
Keep trying
Its called : tetrahedron
Great solution, but as I said - it should be in a few simple steps.
Can you show the steps?
OK. I agree with you, but can you do it if you don’t know the exact degrees?
That angle is a infinite decimal fraction… not exact
@Chayanne
The draft angle should be 30… Normal draft.
Here I had to play hot /cold game some Draft angels had correct length but the angle little off some the opposite
Till I reached this angle.
@Chayanne
I liked the second video
Though mine is easier
