I would like to be able to chamfer an edge at less than 0.1 on any object. On larger objects this is no problem - see pic below - object on the left. I drag out a chamfer - initially goes to 0.1 and then I type in 0.05 and it works just fine. However, can’t drag out a chamfer on the object on the right. I think this is because it is too thin - although it would be big enough to take a chamfer of 0.05. One option would be that when you try to pull out a chamfer on an object that is too thin, the little keypad appears that lets you type in a value - not sure how easy this would be!
