Change from 1st to 3rd angle
Hello good people
I am a high school teacher in Australia and am loving Shapr 3D for the 3D printer but need to present 2D drawings in 3rd angle.
How can I change the default 1st angle setting to 3rd angle
Brad
Hello Brad,
When creating a Drawing, change the Sheet Size setting to ANSI standard. It will change the projection to 3rd angle.
Is there a way to change to 3rd angle but still keep the metric sheet sizes???
TIA Jay
Thank you very much!
Not sure when this changed, but this is no longer the case. Changing to an ANSI paper size does not update to third angle projection.
